Valve seals on 58 FL Duo Glide
  • Valve seals on 58 FL Duo Glide
    45EC0C02-65BA-4F68-8D3C-B9811E8245E2.jpg Hi All,
    I have to decide weather to install valve guide seals on the heads that I am having restored on the 58 Pan head.... they didn’t come with them in 1958 but I am wondering if it’s a good idea to have them 12408C43-C611-413F-9151-58946AC2222A.jpgInstalled now while the heads are on the bench...all new kibble white valves and guides being used...
    Thank you all!
    My experience is if it has the stock oil pump don't bother with seals. If you have a S&S or aftermarket aluminum pump install seals as those pumps tend to flood the top end.
      Stock oil pump will be used if checks out ok... Thanks!!
        I use them on all pans and shovels with kibblewhite valves and Kibblewhite ampco 45 guides
          We do the same thing, no problems.
            Thats what valves and guides are installed... Kibble white... Thanks !!
