Valve seals on 58 FL Duo Glide
  • Steve Galli
    • Nov 2019
    • 93
    45EC0C02-65BA-4F68-8D3C-B9811E8245E2.jpg Hi All,
    I have to decide weather to install valve guide seals on the heads that I am having restored on the 58 Pan head.... they didn’t come with them in 1958 but I am wondering if it’s a good idea to have them 12408C43-C611-413F-9151-58946AC2222A.jpgInstalled now while the heads are on the bench...all new kibble white valves and guides being used...
    Thank you all!
  • D.Ed
    • Jan 2010
    • 26
    My experience is if it has the stock oil pump don't bother with seals. If you have a S&S or aftermarket aluminum pump install seals as those pumps tend to flood the top end.
    • Steve Galli
      • Nov 2019
      • 93
      Stock oil pump will be used if checks out ok... Thanks!!
      • 46CHF
        • Nov 2009
        • 68
        I use them on all pans and shovels with kibblewhite valves and Kibblewhite ampco 45 guides
        • pan620
          • Oct 2016
          • 223
          We do the same thing, no problems.
          • Steve Galli
            • Nov 2019
            • 93
            Thats what valves and guides are installed... Kibble white... Thanks !!
