Speedometer id
  • lrcormier
    • Aug 2010
    • 142
    Speedometer id
    Can anyone ID this speedo, thinking of getting it repaired and refaced for 52 panhead if doable.
  • lrcormier
    • Aug 2010
    • 142
    I think I just identified it as a possible early 70s speedo. If that being the case can it be refaced with a 48-52 face even though those speedos only had three digits in odometer?
    • 1950Panhead
      • Jun 2010
      • 343
      On a panhead cable is male, speedo is female, this is much newer.
        • 6037
        I would guess your core cannot be reconfigured as the 48-52 type. That speedo uses a 2 tiered face, and the numerals are on the glass. Anything can be done, but I don't think speedometer rebuilders would want to do that. I have seen rebuilt originals on ebay in the $650+ range. There is a reproduction of that type, but it's easily spotted by screws in place of rivets. I know where you're coming from as originals are very pricey, and rebuild able cores are hard to find; but they are out there.
          • 4790
          That is not only a '70s unit, but it is totally different internally using different ratios than a Panhead type. It cannot be made to match the required speed so the drive gears in the transmission would need to be changed to get it to function.
          • lrcormier
            • Aug 2010
            • 142
            Thanks for everyone's response. So I guess what my best option is at this point is to try and sell this unit and get what I can and look for a rebuild able unit. Also would appreciate input and what would be the best repop, I've looked at some but hard to tell by pictures.
