I'm looking for a wiring harness for 52 panhead and some people have stated that a harness by Bruce Linsday is best and closest to OEM. Where can I purchase this harness? Or if no longer being made what's the best one to get?
Wiring harness 52 pan
I just did a 51. I got my harness from a well known supplier. Supposed to be the best available and probably is. That being said, it's still a far cry from an original. The asphalt loom is nowhere near what was used in 51 or 52. I fit well but doesn't look right. It wont fit through the holes in the dash base either.
It's peanuts, always buy most expensive, there is a reason.55 dollars difference is quite a spread so I will decide between these two.
