Panhead case picture needed
    • 5950
    Looking for pictures of inside and outside of 1954/'55 cases with the 24563-53A casting number inside of the left case.
  • Speeding Big Twin
    • Mar 2010
    • 433
    Here are four photos I posted for you on FB in September. First one shows casting number 24563-53A and date code 5-4.
    Next two pictures are a 24563-53A case with date code 12 4.
    Last case has casting number 24563-53B and date code 5 5.
    Exactly what are you trying to figure out? I may be able to post other pictures if I know what you’re working on.
    Eric
      • 4784
      Well he did say left case....
      Here is an inside picture of a left side late production 54FLE. Note it is a -53 not 53A case with a date code of 9-3.
      And here is the outside
      The belly numbers match, the VIN is about 50 digits earlier than the belly, the right case is also -53 and dated 8-3.
        • 5950
        Thank you all for the great pictures. Now if we can find the difference between the -53 and -53A.
          • 5950
          Eric
          We are trying to find the difference between the -53 and -53A.
          • Speeding Big Twin
            • Mar 2010
            • 433
            For R-H cases with casting number 24563-53 my latest example appears to have date code 9 3 but I don’t have pictures showing the entire case. Earliest I have with 24563-53A has date code 5-4. What happened during that period? Could the change in casting from 24563-53 to 24563-53A have something to do with a change to the pinion shaft bearing?
            Also notice a difference in the channels in the R-H cases below. First has casting number 24563-53 and date code 10 2.
            Next case has casting number 24563-53A and date code 5-4.
            Eric
              • 2019
              When did they remove the concave hole for the generator strap from under the generator perch. Jerry
              Eric
              • Speeding Big Twin
                • Mar 2010
                • 433
                I don't know. I haven’t got enough clear pictures. It was still fairly pronounced in Jan-Feb 51. It looks good for Oct 52. And perhaps Mar 53. One example from May 55 looks like it was messed with later on.
                Eric
                  • 4784
                  Jerry,
                  I have a '57 belly numbered -53A right case date coded 5-5 and the generator boss is flat, no concave.
                  Robbie
