Glass beading crankcase
  • Shaky Jake
    Ol' Poop
    • Jan 2013
    • 261
    #31
    On aluminum I use the plastic blast media that TP Tools sells. It removes paint and dirt really well and does not change the appearance of the aluminum. If you’re interested, I probably have some before/after pictures I could post.
    Kevin
    Kevin
    • Steve Galli
      • Nov 2019
      • 93
      #32
      Kevin
      Thank you Kevin... I am thinking just gunk and scrub is the way i will go...
      • Shaky Jake
        Ol' Poop
        • Jan 2013
        • 261
        #33
        I understand. Nothing wrong with that.
        Kevin
        Kevin
        • Hack
          Senior Memeber
          • Sep 2010
          • 91
          #34
          White vinegar and a stiff plastic, (not metal!) brush will help clean aluminum once you get the crud off.
          • Kozy
            • Feb 2004
            • 129
            #35
            Straight vinegar or dilute with water?
            • Hack
              Senior Memeber
              • Sep 2010
              • 91
              #36
              Right out of the bottle it will remove oxidation and similar funk without removing or pitting the aluminum. You can rinse with water. Leaves a nice smooth patina as you can see below the rear tappet guide.
              • Steve Galli
                • Nov 2019
                • 93
                #37
                [ATTACH=CONFIG]26324[/ATTACH]
                Looks very nice! Thank you for the idea
                • Peter Cooke
                  • Aug 2012
                  • 572
                  #38
                  And it doubles as weed killer when you're done cleaning with it!
                  • Kozy
                    • Feb 2004
                    • 129
                    #39
                    Thanks Hack, I'll give it a try.
