Glass beading crankcase
  • Steve Galli
    • Nov 2019
    • 93
    Hello all,
    Have an 1958 FL that needs going over....
    Is glass beading the cases a good idea are there other methods the way to go...
    Worried about left over debris causing harm to new internal engine parts...
    Thank you!!
    Welcome, Steve!
    Just coat the insides...
    (Unfortunately, both Gasoila and Glyptal failed in my fuel immersion tests, which would simulate a bad petcock on an OHV. So I haven't many suggestions..)
    • govmule84
      Fat & Cranky
      • Dec 2014
      • 179
      Hot tank? Vapor blasting?
      Depends a little on your aesthetic desires a bit, I think.
      • Steve Galli
        • Nov 2019
        • 93
        Yes... I was looking at vapor blasting... just need to find a vendor for it... definitely want to clean up the outsides
        Thank you!
        • Steve Galli
          • Nov 2019
          • 93
          Thank you! Last time this engine was done was the eighties... hope I like what I find....
          thank you all!
          • larry
            • May 2009
            • 247
            Simply scrubbing with detergent and water will make a big difference. Abrasive blasting should be avoided. Baking soda blasting is safe, but will change the appearance somewhat.
              Golly Steve!
              I'd certainly throw detergents at it before money.
              Pine-Sol!
              Some swear by it.
              PS: But they say its got to be the real thing.
              • Steve Galli
                • Nov 2019
                • 93
                Thank you! This is what I was thinking....
                • Steve Galli
                  • Nov 2019
                  • 93
                  Golly Steve!
                  Pine-Sol!
                  Some swear by it.
                  Thank you! Will try this...
                    And please note, Steve..
                    HD coated inside their cases,...
                    Even though they were (probably) never blasted.
                    • aumick10
                      • Nov 2018
                      • 465
                      Welcome, Steve!
                      Cotton,
                      Have you done any tests on Ethanol free fuel?
                        • 6036
                        Good advice. I don't glass bead any motor parts, and particularly aluminum castings. I clean castings in our laundry sink and use anything from TSP, Comet, Dawn, scrub brushes, scouring pads, and tooth brushes. You'll never make your cases look like they did when H-D put them in a frame, but you can come close.
                        • kitabel
                          • Sep 2018
                          • 471
                          I've found embedded glass beads in the surfaces of carefully cleaned aluminum castings, and in other very bad places (behind races, blind threaded holes, inside oil passages, snap ring grooves, etc.).
                          A few thousand vibrations later, they reappear and flush through the oil system as an abrasive slurry.
                          The Linkert Book
                          • Steve Galli
                            • Nov 2019
                            • 93
                            Wow.... exactly what I feared... Does not sound like a recipe for a long running motor... Thank you!
                            • larry
                              • May 2009
                              • 247
                              A friend, as an experiment, blasted a piston. He then scrubbed it with detergent and hot water. He then put it in a pot of water and boiled it. When he finished, there was sand at the bottom of the pot.
