panhead crankcase
  • hairynob24
    • Feb 2011
    • 348
    panhead crankcase
    G,day can someone tell me if the crankcase mounting bolt pattern on a panhead would be the same as a vl or wla ? I have a bent frame and 3 of my contacts have asked for the rear wheel to be installed with the tranny and crankcase . The crankcase is a right off broken beyond repair , and missing parts too. I don't have a panhead crank to use for the frame guy , Rob
    Same as VL but different than 45". Although the pattern is the same as VL the height if the mounts themselves differ. If you need your left case repaired of replaced contact Phil at http://knuckleworks.com/ph4854.html
    • hairynob24
      • Feb 2011
      • 348
      thanks Chris just what I needed to know Rob
      • kitabel
        • Sep 2018
        • 471
        UL - knucklehead: same pattern, same height difference fronts/rears
        VL - knucklehead/UL: different pattern, same height difference fronts/rears
        Panhead/shovelhead - knucklehead: same pattern, different heights (by 3/8")
        The Linkert Book
        • hairynob24
          • Feb 2011
          • 348
          ok kitabel cheers back plan B my son has Vl cases so I will need to ask around
