Hi Guys
I'm restoring this to the 'Deluxe' spec., but I prefer the predominantly black image on the enclosed to the more chromed parts on the 'proper' Deluxe spec on the 1948 order form, which are broadly what the other images are, though none seem to be officially correct to Palmers definition.
On the painting
In 1948, could you order different parts to be chromed than the 'Deluxe' spec, to achieve what I want?
If the answer to the above is 'no', and I paint this predominantly black which is a lower spec, would points be deducted in the judging?
Thanks for your support
Greg
On the painting
Greg
