48 Neck forging
  • 38plymouth
    • Aug 2016
    • 39
    I thought I would take a chance and get a forging from V-Twin. The bore for the stem was off center. The machining for the bore for the down tubes was so off center, it left what remained of the casting paper thin. I returned it as they indicated none of them were perfect but were OK as is!!. V-Twins idea of OK is not OK. I contacted Wasco hoping that he did his machining in house but that was not the case. In as much as no matter what I do will not make this a correct frame for a restoration, I have decided to simply de-rake it with steel gussets. Wasco offers a de-rake kit for $28.00. I have access to a frame table and tech that built drag race frames.
    • 41craig
      • Nov 2010
      • 410
      Just my 2 cents. If you install the Wasco lock casting # (W-076) and cleanly dress the welds, it will make your frame worth more than just using the derake kit. Although it's $90.00 vs. $28.00.
      Craig
      • 38plymouth
        • Aug 2016
        • 39
        Craig, that was worth at least 10 cents. I just ordered the lock casting and the the lock. Richard said he would throw in the lock pin assembly if he can find one. Thanks for the heads up.
        Sam
        • 41craig
          • Nov 2010
          • 410
          Sam
          No charge !! V-twin sells the lock kit if Wasco is sold out.
          Craig
            • 5950
            Wasco is expert at restoring raked necks and making them look like new.
            • 38plymouth
              • Aug 2016
              • 39
              De-rake project progress.
              Used the lock casting from Wasco as suggested by 41 Craig
              • 38plymouth
                • Aug 2016
                • 39
                De-rake complete
                Alignment is spot on. It might be an un-molested frame but it will suit my needs.
                Thanks for the advice.
                • Sargehere
                  Member since 1972
                  • Jul 2006
                  • 971
                  Congratulations on a job well done. Have followed this thread, back since June, and your photos show a patient and worthwhile job. You increased the value of your frame just by creating a potential home for another Harley engine. Ideally, All any one of us wants to do is to bring another "Old Harley" back to life. Geez! Good job!
                  Gerry Lyons #607
                  http://www.37ul.com/
