'48 FL Panhead - 6 volt or 12 volt????
  • harleygreg
    • Oct 2018
    • 215
    Hi Guys - the electrics on this bike are giving me a headache.
    The generator - see image - is a model 61, which I believe is 6 volt, 2 brush, and from a 1961 - 64 bike. The regulator - see images - looks like 74510-47A, which I believe is also 6 volt and used on 1958 + bikes. I can't see what the coil is, and no battery was supplied with the bike. The bulbs are a mixture of 12 and 6 volt.
    Is the above right, and therefore, is the bike a 6 volt machine?
    Whilst I want to get the bike as original as possible, I'm thinking of refurbing the model 61 generator, (as it gives greater output than the original), and using a 6 volt (electronic) cut out/regulator which are now made identical to the original cut outs, and positioned in the same place?
    • 4790
    The model 61 would be a perfectly fine one to use. When getting yourself a regulator make sure they know you are using a two brush as opposed to three brush generator and it will all work just fine.
    • 1950Panhead
      • Jun 2010
      • 343
      Get a 6 volt battery and check voltage with engine running, 6.5 or 12.5 dependant on original field coils and armature or updated parts.
      32E generators use a cut out relay, 61 generators use a voltage regulator.
      • BigLakeBob
        • 2768
        Samwel makes a 6v and 12v regulator that looks like a cut out relay and accepts the original relay cover. I think that is what harleygreg is referring to. I bought a 6v one for a project that I am going to run a model 58 on a 45" flathead.
        Bob Rice #6738
        • harleygreg
          • Oct 2018
          • 215
          thanks guys, I've rigged the bike as 6v with a 6v electronic relay referred to with 6v bulbs etc. Once it is all running I'll check the charging voltage and go from there.
          Thanks for your help
