Replacement steering lock key for '48 FL frame
  • harleygreg
    • Oct 2018
    • 215
    Hi Guys, I have a genuine 48 frame with the lock intact - any ideas where I can find a key - there do not seem to be any codes on or near the lock
    Greg
  • Magic
    Magic
    • Dec 2002
    • 282
    An actual locksmith can easily make a key using the Briggs and Stratton type key blank as your ignition. Those neck locks get rusted inside and will require a lot of penetrating oil and loosening technics.
      • 4790
      If it is a genuine frame with the original lock there is a code on the face of it. If the lock was replaced with a later one there is not due to the stainless cover used.
      • Jcadams
        • Nov 2018
        • 45
        I brought my frame to a locksmith and he used a MACK blank. As in truck
        • Sargehere
          Member since 1972
          • Jul 2006
          • 971
          It is a standard key (the Briggs&Stratton pattern) that a competent locksmith can almost look at and figure out. It is a project to put your frame in front of a locksmith's eyes but that's all you have to do. You won't be the first to haul your frame to a locksmith's shop.
          Gerry Lyons #607
          http://www.37ul.com/
