Same speedo, same seller 2 weeks apart. What happened? Jerry
1948 to 1952 speedometer
https://www.ebay.com/itm/-/153065423...2047675.l10137
https://www.ebay.com/itm/-/153083956...2047675.l10137
Jerry, click on the word "listing" when you get the message "The listing you’re looking for is no longer available. Check out this similar item we found for you." it is a hyperlink to the original auction.Originally posted by Jerry Wieland View PostI tried a link but now eBay will direct you to 'similar auction' if an auction has ended. The last week or two I have found it almost impossible to look at an auction that has ended. Jerry
hope that helps!
I am also having great difficulty with the E Bay site. I used to just enter the range of years desired and the distance from zip code desired , easy peasy. Now (last week or so) I cant even find any of those options which made viewing ALL the old motorcycles available, possible. Very Frustrating. Smitty
Originally posted by Rubone View PostThat number doesn't work. Why not post a link?
Starting bid was $250.00
Search item number 153065423617 under completed auctions.Last edited by Chris Haynes; 06-24-2018, 11:00 PM.
What is the general thought on this. Jerry
Completed eBay auction number 153065423617Last edited by Jerry Wieland; 06-24-2018, 09:32 PM.Tags: None
