1948 to 1952 speedometer
    • 2020
    What is the general thought on this. Jerry
    Completed eBay auction number 153065423617
    • 4784
    That number doesn't work. Why not post a link?
      • 5950
      Starting bid was $250.00
      Search item number 153065423617 under completed auctions.
        • 2020
        I tried a link but now eBay will direct you to 'similar auction' if an auction has ended. The last week or two I have found it almost impossible to look at an auction that has ended. Jerry
        • HDSmitty
          • Jul 2017
          • 282
          I am also having great difficulty with the E Bay site. I used to just enter the range of years desired and the distance from zip code desired , easy peasy. Now (last week or so) I cant even find any of those options which made viewing ALL the old motorcycles available, possible. Very Frustrating. Smitty
          • JohnA
            • Aug 2014
            • 10
            Speedometer
            • 46WL
              • Feb 2007
              • 60
              Jerry, click on the word "listing" when you get the message "The listing you’re looking for is no longer available. Check out this similar item we found for you." it is a hyperlink to the original auction.
              hope that helps!
                • 2020
                Same speedo, same seller 2 weeks apart. What happened? Jerry
                https://www.ebay.com/itm/-/153065423...2047675.l10137
                https://www.ebay.com/itm/-/153083956...2047675.l10137
                  • 4784
                  The acid ran out!!
