Panhead Tires
  • shovelheadstan
    • Nov 2017
    • 45
    Panhead Tires
    Any thoughts or suggestions out there about what kind of tires to run on a 56 pan.
  • Rollo
    • Nov 2008
    • 599
    I run the Shinko copy of Goodyear's from J&P. They are half the price of Coker's and are speed rated. Haven't had any issues. I run the Avon's on my knuckles.
    Tom (Rollo) Hardy
    AMCA #12766
      • 2025
      MK3 Avons. Solid old look tire with none of the issues of Coker which I would not run on my wheel barrel. Only negative from me is less mileage than
      some late model tires.
      • knucklehead 61
        • Sep 2016
        • 355
        i was docked 2 points for having beck type tires on my 55FL last year, so I also need to know what tires should be on my bike.
        • upsrod
          • Feb 2010
          • 320
          Pretty sure that they will get you for something!
          • JSB55
            • May 2009
            • 332
            Watch out for any tires with a "classic" tread pattern ... my 65 runs fine on asphalt, but we have a lot of grooved cement pavement where I live, and that "classic" tread pattern wants to follow the grooves in the cement, which causes *severe* front end shaking and wandering ... can't wait to get rid of those tires and put on something with a modern tread pattern and stash the "classics" away for use only if I ever want to show it for judging
            Ride it like you can fix it!
            • jwl
              • Dec 2001
              • 338
              MK3 Avons are horrible on grooved concrete. If there is none of that where you ride, they are a good choice.
              • hennigan62
                • Sep 2010
                • 140
                i have run coker on my 62 for several years now with no issues. all roads from interstate to the dragons tail. would buy them again.
                • vph-d
                  • 1088
                  The Avon Safety Mileage tires work well except on rain grooves. The Continental 112 is another choice, and is a little better on rain grooves.
                  VPH-D
                    • 6044
                    I've also run Cokers on both my panheads, and a '40 Chief with no problems at all. However, they are a soft compound and wear quickly, particularly when I ran a sidecar. I thought they were good in the rain, which we get a lot of here in Florida. Having said all that, my next pair of tires will probably be Shinkos for my '51FL because I like the look, and friends have recommended them. We have 2 draw bridges here in Sarasota and every motorcycle tire has been squirrely on those steel grates, including a Sportster with Continentals.
                    • KNUCK
                      • 828
                      Just put Shinkos on my '49 and '58 but running original Goodyear on the '65.
                      • shovelheadstan
                        • Nov 2017
                        • 45
                        Thanks to all for the information
                        • Schorsch
                          • Feb 2009
                          • 91
                          I run and tested 4 different classic tires on my rigid frame Panheads.
                          AVON MK2, Continental K112, AllState and Coker/Beck style thread.
                          I can say, never use the Coker/Beck style tire. They are dangerous for your life. They are very slippery on wet roads - You cannot stop!
                          AVON MK2 are a good choice, but the Continental K112 I feel is better on uneven roads and has grip on dry or wet roads.
                          Also very good is the AllState Tire 5.00-16. Made in Japan and the most expensiv of all.
                          • 46CHF
                            • Nov 2009
                            • 68
                            I have put Shinko 270’s on lots of pans and shovels. They are a replica Goodyear supereagle pattern which was used by Harley Davidson till 1968. Have not had any problems and run them on my own bikes
                            • 46CHF
                              • Nov 2009
                              • 68
                              Shinko 240’s are the speed grip pattern used by harley-Davidson after 1968. They can be a little squirrely on grooved pavement and iron grate bridges I prefer the 270 supereagle pattern. They are a little taller profile. They look good and wear well
