1965 Electra Glide clutch and brake levers
  • craig (DE)
    • Oct 2010
    • 344
    Hello,
    Can someone provide a picture of the correct levers for the clutch and brake on a 1965 Electra Glide? I know there are no holes in the perches since the mirrors clamped to the bars but do the levers have the ball on the end or are they straight? I've been searching but coming up with conflicting results.
    Thanks!
    Craig (Delaware)
    Delaware Bay Chapter
    Perkiomen Chapter
    AMCA Member #1011
  • upsrod
    • Feb 2010
    • 320
    They are straight and have the ball on the end...the same lever as the later models, but no hole in the perch. Your confusion probably comes from assholes on eBay claiming the lever they are selling is a 1965 with no hole and is in fact a 1964 and back lever.
    • vph-d
      • 1087
      65 thru 67 levers don't use the white plastic top hat bushings.
      VPH-D
      • craig (DE)
        • Oct 2010
        • 344
        Thanks for the clarification. And you are right about the sellers on eBay!
        Craig (Delaware)
        Perkiomen Chapter
        AMCA Member #1011
        • craig (DE)
          • Oct 2010
          • 344
          VPH-D
          Thank you!
          Craig (Delaware)
          Perkiomen Chapter
          AMCA Member #1011
            This info also applies to 1965 Sportsters as well. Bob L
            • 55tmm
              • Dec 2009
              • 158
              Here is a picture of '65 lever and brackets
              • craig (DE)
                • Oct 2010
                • 344
                Thanks for the picture.
                Craig (Delaware)
                Perkiomen Chapter
                AMCA Member #1011
