linkert M74B+#1Jet
  • hdhikaru
    • Feb 2010
    • 217
    linkert M74B+#1Jet
    hi, my 74b carb has #1 jet... is this right one? I think its too lean.
    the carb is on 49FL. please advise.
    • 2044
    was probably run on 45" WR...try a #19........................................or maybe 18. I have seen this before but with a #5
      • 8247
      Hdhikaru!
      Many were poorly stamped; The '9' may be invisible..
      A #19 would have a .099" opening (2.52mm) with last eighth of an inch (31.8mm) of its bore drilled to .082" (2.08mm)
      A #1 would have a .052" (1.38mm) bore, and could be drilled out, although its final sizing should be lapped.
      Beware of common catalog offerings that are not even close!
      PS: Duffey!
      The M74 with no 'B' used the #17, but it also had a different highspeed needle point.
      • hdhikaru
        • Feb 2010
        • 217
        thanks for the big help ! will try big one.
