Fixture
  • Steve Little
    • Apr 2008
    • 915
    #61
    Hi Peter. I had a quick look and could only see 6 messages in there.
    It took another 15 minutes to work out that I needed to click another box to see that I had replied to 44 messages.
    I'm not the sharpest tool in the shed.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    • Peter Cooke
      • Aug 2012
      • 572
      #62
      Thanks Steve,
      PM inbound.
      • BigLakeBob
        • 2768
        #63
        I use these when checking diameters. Nice to use on the machine and when checking in hand. I also find bearing sizes ranging all over the place.
        Bob Rice #6738
        • Steve Little
          • Apr 2008
          • 915
          #64
          Nice. The barrel reads 001" and the gauge reads 0001".
          Steve Little
          Australia.
          AMCA member 1950
          • BigLakeBob
            • 2768
            #65
            Reading your reply makes them sound inaccurate I must admit, but they are meant to be set at any given size by using gage blocks which are in .0001 increments. If I am grinding a diameter I use my standard mic until I get under a .001 then use these to finish, my OD grinder moves in .000025 increments. When checking 1/4" bearings I would set the mic using .2500 gage blocks then read the dial +/- in the .0001 increments. Not trying to sway from your thread, just thought I would share another type of measuring device.
            Bob Rice #6738
            • Steve Little
              • Apr 2008
              • 915
              #66
              G,day Bob.
              No inaccuracy intended.
              Without facial expressions and tone of voice, there is a phenomenon where text sometimes looses its intended mark.
              The word "Nice" is to show my appreciation for your gauges and functionality of the dual readout.
              The description " barrel reads 001" and the gauge reads 0001" refers what I like about your gauges.
              Appreciate your contributions to the thread.
              Regards Steve
              Steve Little
              Australia.
              AMCA member 1950
