61 Panhead, belt drive, original primary cover
  • 68bagger
    member
    • Mar 2010
    • 23
    Is anyone running a 1 1/2 inch belt drive with the original primary cover. Any problems? I'm looking at a BDL brand. Any info will help.
    thanks, Scott
    It should fit.
    A belt drives enemy is heat. Get a repop inner primary cover and by using a 1/2", or larger, drill bit make it look like a piece of Swiss cheese.
    • vph-d
      • 1088
      The belt fits in the stock primary covers just fine. I've drilled a few holes in the inner cover, and spaced out the inspection cover with a couple of flat washers, too.
      VPH-D
