Probably a simple rocker question...
  • panheadfred65
    • Sep 2014
    • 8
    Could a bigger cam cause that?
    • billpedalino
      • Mar 2005
      • 1096
      Unless the valve guides were cut down and the spring travel checked and/or the collars were changed, a higher-lift cam would cause coil-bind long before the rocker arm would hit the pan cover.
      Bill Pedalino
      Huntington, New York
      AMCA 6755
      • Highlander
        • Feb 2006
        • 97
        What about pushrod length?
          • 4787
          Pushrod length has no effect on the relaxed or open position of the rocker arm. Unless of course it is grossly out of adjustment. But in that case the engine won't run!
