Probably a simple rocker question...
  • Dablaze
    • Apr 2011
    • 157
    Hi,
    I am working on a friends '58 and found that the intake rocker is tapping the inside of the cover. I believe that I heard that this is common. The rocker itself has a touch of weld (pushrods end) that seems to be the culprit. Two questions, what would be the reason for the weld and is the solution to just take this down some?
    Craig
    • 2024
    Culprit is not the weld but either you have a short stemmed valve or the rocker arm at the valve stem has excess wear. I've seen both be a problem.
    Jerry
    • Dablaze
      • Apr 2011
      • 157
      Ok, good point, but it does seem to have a pointy tag that's not illustrated in the lousy pic.
      I will go through every thing though. Thanks!
      What's the reason for the weld, there's a blob on every rocker. On the pushrods side.
      Craig
        oil passage.
        • motorhead1
          • Dec 2006
          • 171
          Jerry
          True. Also consider that the rocker arm pad could have been ground to clean up the valve stem wear and too much was removed. A problem I see a lot is when someone has tried to compensate for valve seat recession by installing an oversize head valve and not cutting the seat to get proper stem protrusion. You can tell if this is the case by measuring the installed height of the spring assembly. While they wont be exact on a worn engine, both spring heights should be very close.
          Ride 'em. Don't hide 'em.
          Dan #6938 FUBO
          • larry
            • May 2009
            • 247
            You can file it flat but not through to the passage.
            • Dablaze
              • Apr 2011
              • 157
              Thanks all!
              It's a rider, put together from used parts and aftermarket stuff, so nothing special. Most of the engine looked pretty new.
              Could we just ball pecan a little clearance into the cover until it's time for a rebuild?
              Craig
              • BigLakeBob
                • 2767
                Originally posted by Dablaze View Post
                Thanks all!
                Craig
                Sounds like it is time for a head rebuild, not like you have to do the whole motor. You're in there, why not fix it right? It will haunt you down the road IMO.
                Bob Rice #6738
                • Dablaze
                  • Apr 2011
                  • 157
                  Pulled the head, everything is fresh, good seats. I had the owner helping me out and at one point I looked at him and he had the pushrods in his hands and he was holding one of them upside down. I am guessing that that one might have been in the motor that way, which I think is the issue.
                  Craig
                  • motorhead1
                    • Dec 2006
                    • 171
                    Craig, the photo you posted clearly shows the pushrods installed correctly, so that is not your problem. Remove the intake spring and check the stem protrusion. The specs are in the manual. If it's good then you have a rocker arm issue.
                    Dan #6938 FUBO
                    • billpedalino
                      • Mar 2005
                      • 1096
                      If the rocker arm is hitting the inside of the pan cover, my money is on an excessively deep valve seat. The service manuals for each model give the maximum valve height measurement from the top of the installed stem (no springs or collars) to the base of the valve guide. Being too lazy to pull out my books right now and without looking, I believe that the correct maximum distance for panheads is 1.75", but check that. If its more, the rocker arm will most likely hit the inside surface of the pan cover.
                      Bill Pedalino
                      Huntington, New York
                      AMCA 6755
                      • Dablaze
                        • Apr 2011
                        • 157
                        Ok, pulled the head, the valves sit nice and freshly proud, it's definitely a fresh build. I am not sure from the pic, but I am very certain that when I went back to the pushrods (I leave them in the tubes and sit them in the order I take them out) one of the rods was large ball up and one was small ball up. They are mated to adjustable tappets (I am assuming that this was a conversion kit, probably from Colony?)
                        The valve stems on the same head measure up the same out of the head, but that is measuring one exhaust and one intake...is that correct?
                        If I am wrong about the pushrods being upside down then it has to be the face of the rocker where it meets the valve, correct? Any way to determine this other than process of elimination?
                        Thanks again for all the help!
                        Craig
                          • 4787
                          That only occurs on the valve end of the rocker, his is hitting the pushrod end, which generally indicates too little valve stem protrusion, the opposite problem.
                          Craig,
                          Check the stem protrusion. It involves removing the springs and collars, but is an important measurement. Just because the parts are new doesn't make the job right.
                          • larry
                            • May 2009
                            • 247
                            Photo of pushrods and adjusters?
                            • billpedalino
                              • Mar 2005
                              • 1096
                              Craig,
                              You're correct Robbie - I didn't see the photos and didn't realize that the interference was on the right side. Sorry for the misinformation Craig, short valve stems would be a first guess.
                              Bill Pedalino
                              AMCA 6755
