1953 FL Clutch Booster Cover
  • billpedalino
    • Mar 2005
    • 1096
    I recently painted my steel mousetrap spring cover black. I then decided to read the NEW Bruce Palmer 'Bible' (I sometimes do things backwards for added drama). In doing so, I learned that it appears that this cover was stainless steel only for the1953 model year . The 1952 and 1954 covers were black-painted and subsequent years were cadmium plated or chromed, depending upon the options package.
    Mr. Plamer's photo description on the bottom of page 947 denotes that stainless steel was used for this cover in 1953. However, the spring and cover are listed as black-painted parts in 1953 on page 949. It does seem odd that the cover would be black in '52 and '54 but stainless in '53 only - and then then switched to cad-painted in '55. but this is entirely possible. Maybe they liked the look of the light-colored cover, but stainless proved to be expensive and eventually switched to cadmium as a cheaper way and offered chrome plating to generate more profit under the various options packages.
    Finally, I've never seen a stainless steel mousetrap spring cover, but then again I never looked for one and old, dull stainless can easily be mistaken for cadmium-plated mild steel.
    If anyone can shed some light on this cover material before I go on a wild goose chase, I'd appreciate it.
    Thanks...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • jwl
    • Dec 2001
    • 338
    My original paint 53 has a black painted cover. It may be black painted stainless steel, but that wouldn't make much sense.
    • billpedalino
      • Mar 2005
      • 1096
      Thanks JWL - to me, the black painted part makes sense...
      Bill Pedalino
      AMCA 6755
      • jwl
        • Dec 2001
        • 338
        Magnet sticks to it so apparently it is not stainless steel.
        • upsrod
          • Feb 2010
          • 320
          Several OEM Harley SS parts are magnetic.
            • 8247
            Folks,
            Non-magnetic stainless sheet becomes magnetic when it is pressed to shape, explaining magnetic aircleaner covers, fender trim, and the like.
            Yet I believe the spring cover was ordinary steel, often chromed,.. but then I've never owned one!
              • 2044
              SS with iron added for malleability will attract magnets. pure SS does not.
                • 8247
                Explain this, Duffey!
                Here is a piece of SS sheet that is not attracted to a speaker magnet at all on its flat end, but the other end that I just dimpled in a dome block and flattened back out sticks.
                Scrap buyers with magnets have been ripping off scrounges for years.
                  • 2044
                  I worked with SS for 17 years.The product we produced reacted with iron.We had to use 316L SS [pure SS] and when welded had to be acid washed w/nitric & hydroflouric acid to clean the welded area.316L is very hard & brittle not maleable[bendable].Iron added to SS makes it slightly less hard and maleable.still SS.there are varying degrees of iron added for different purposes.Your 6" SS ruler wil attract a magnet and will rust if exposed to moisture/cemicals for extended periods.
                  The sheet metal we used in plant that was not in contact with the outgoing product was less than/not 316L.You could bend weld etc. and it would not attract a magnet.It would slightly rust if exposed for long periods to product & water.There are many types of SS most has iron in it.If it attracts a magnet it it is not pure SS.The sheet metal we used for conveyors,trays etc was 304 SS.The product would turn colors if left on it,but even after bending & welding would not attract a magnet.
                    • 8247
                    That's great, Duffey,...
                    But please explain why my piece of scrap that has been in the weather for years without corrosion is suddenly magnetic, only where it has been worked?
                    PS: I've been around stainless enough to smell it in a pile.
                      • 2044
                      It has some iron in it and thats why it did not break when bent and why the magnet sticks.I'm not saying there isnt a diff magnet attraction when bent,just saying it is not pure SS.And less pure than 304 wich will not rust in just water,but with other chemicals and water it will show slight surface rust.It also does not attract a magnet when bent.My SS rulers will attract a magnet & rust with just water but rust wipes off easily
                        • 8247
                        But Duffey!
                        There is ZERO attraction before the metal is worked, only after worked back and forth; Seriously: non-magnetic stainless can be made magnetic.
                        And how can anything be a "steel", stainless or not, without some iron?
                        And that is why pressed vintage pieces are magnetic, whether they were 'pure' or not. If it tarnishes at all, I wouldn't call it "stainless", and H-D "stainless" doesn't tarnish, even when it is magnetic.
                        When in doubt, I just smell it.
                          • 2044
                          Read my posts,there is iron in it.But telling you anything is wasting my time..And it does tarnish,I clean it with SS cleaner & polish all the time
                            • 8247
                            Sorry Rod,
                            You gotta replace the aircleaner cover on your '65, because its magnetic!
                            (Even if you don't have to 'polish it all the time'.)
                            Somebody better warn Bruce Palmer III to hold the presses on his next edition....
                            PS: Now all of the AMCA judges must be equipt with compasses to detect magnetism.
                            My '65 aircleaner shows a pole at the maintenance script. Might as well scrap it.
