Pannier lock
  • Steve Little
    • Apr 2008
    • 915
    Pannier lock
    Hi.
    Can anyone help with info on a supplier for the pre 70's pannier lock.
    Iv'e found the lids don't stay on so well, without them.
    Regards Steve
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    • 2044
    They don't stay on so well with them either..a freind used to find lids on the way to swap meets and then sell them to the guy that lost them-I'v seen many pinned to keep latched
    • RichO
      • Dec 2001
      • 903
      With pre-70 fiberglass bags you drill a small hole through the front of the cover clip and after it's install on the bag bottom you insert a small "bobby pin" as their called in the trades. It's easy to lift the back of the lid to put something in the bag without pulling out the bobby pin all the time. Locate one of the proper keys to lock the back latch and it should b fine. The key is a very small sheetmetal item and has a -62 part number. I can't get to mine right at the moment but when I do I'll post the key number and maker. their on the key. If you keep the latches lubed and their in good working order they work well. Hope this helps. V-twin might make replacements if I remember correctly but buyer beware.
      DrSprocket
      • Steve Little
        • Apr 2008
        • 915
        Thanks for the fitment ideas.
        Appreciate the supplier suggestion, but I will hold out until I find an original.
        Steve
        Steve Little
        Australia.
        AMCA member 1950
