Greasing wheel bearings
  • karlk
    • Aug 2014
    • 5
    Hello everyone,
    When greasing front wheel bearings thru the grease fittings should I pump
    the grease in until it comes out the ends of the axles, the owners manual
    makes it sound like to much will get all over the brakes. I have a 62
    Flh, 57 kh and a 47 knuckle head, none of them have been used for many
    years.
    I know I need to remove the wheels to really see what is going on in there
    but just trying to get things lubricated so the can be ridden sparingly
    to see what else they may need.
    Thanks, Karl
  • wideglide38
    • Jul 2008
    • 656
    Karl,
    I remember reading in my Pan manual that after rebuilding hubs you squirt 1 oz. of grease into the hub through the grease fitting. The MoCo also noted excess grease may/would sling into the drums.
    I'm guessing I need to find a "metering" grease gun! Ha-ha!
    William
    William Edwards, AMCA #10035
