Panhead wiring routing
  • camsaure
    • Nov 2009
    • 135
    Hi, The 50 FL is almost done, but I have several questions on wire routing, clips etc. Tried doing a search but always come up with several pages of totally unrelated stuff.
    Most of my questions are around the neck area; Which way the harness goes through the neck clip. The routing of the horn wire. Which is the correct clip for the generator wire on the front down tube?
    Next I have questions on the spark plug wire length and routing. was there supposed to be a clip on the frame or were they just loose in the wind with the exception of the motor mount clip?
    Was there a clip on the frame for the taillight wire?
    Also Chris Haynes if you are reading this, Do you have any of those excellent close up photos of 49-50 Panheads? I have noticed you post some excellent pics of other bikes in the past.
  • dlark
    • Dec 2011
    • 12
    Here's the 49 at the museum
    museum 2 020.jpgmuseum 2 021.jpgmuseum 2 022.jpgmuseum 2 032.jpgmuseum 2 043.jpg
    • camsaure
      • Nov 2009
      • 135
      Thanks for the help. dlark
      • dlark
        • Dec 2011
        • 12
        Came across these today if you're still working on it. Scroll to the Persian Red and he's got some wiring pics.
        • camsaure
          • Nov 2009
          • 135
          Thanks again. According to those pics I had everything right except I put the throttle cable on wrong side of neck. Palmers book, in two different places gave conflicting info on cable routing.
          • dlark
            • Dec 2011
            • 12
            I'd like to see any pics we could. I'm just starting to wire a 52 Pan and the wire/cable routing seems to be one of the toughest areas to figure out.
              This should help and off to Oley! Bob L
                And more!
                • dlark
                  • Dec 2011
                  • 12
                  Thanks Bob- These are a huge help.
                  Dave
