Pan trans question
  • sprglde
    • Apr 2011
    • 24
    Pan trans question
    Hey, I have a 64 FL cop bike with 3 speed and reverse that I want to change to a 4 speed. Can this be done with my tranny case or do I need a 4 speed case? Thanks.
    • 2024
    You should be able to use your tranny case but only high gear, 3/4 shifting fork and the mainshaft of the rest of it can be used. Jerry
      • Feb 2003
      • 5353
      I'm sure that all '36 - '64 cases are pretty much interchangeable. If you were looking to do the opposite procedure you may have had to do a little "relief" work for that reverse gear. You should be good to go! I'm sure others may weigh on the subject though.
      Well there you go... Jerry did!
      Cory Othen
      Membership#10953
      • cdndewey
        • Jan 2005
        • 438
        Hello Bob....I sent you a Private Message
        • camsaure
          • Nov 2009
          • 135
          Isn't the shifting drum different also? I am pretty sure that it is.
          • cdndewey
            • Jan 2005
            • 438
            Yes...the shifting drum from a 3 speed reverse won't work with a 4 speed...........unless of course it's a 39 with neutral between 2nd and 3rd.
            • sprglde
              • Apr 2011
              • 24
              Hey thanks for the info n I'm sure I'll have plenty more questions when I get into this. I'm definitely not lookin foward to the winter but really lookin foward to a 4 speed.
