Need help with inter primary cover for 1961 duo glide
  • 61 pan
    • Dec 2012
    • 17
    Help can someone tell me does the lower tab on the inter primary cover mount to the inside or outside of the tab on the frame. While I'm here just to make sure ill ask the same question for the top one on the oil tank. Also does the spring go between the two tabs or on the backside of them.Thanks
  • Robert Luland
    • Sep 2007
    • 2075
    Primary tab goes on the outside of the frame tab. Bolt goes on the inside with threads facing out. Then the inner primary, spring, washer ,nut and cotter pin.
    AMCA #3149
    • 61 pan
      • Dec 2012
      • 17
      Ok great that is what I thought but I noticed the the breather nipple was not sealed against the inter primary cover. I already had the clutch, chain and sprocket installed when I noticed it.
      • Robert Luland
        • Sep 2007
        • 2075
        When you say breather nipple? Are you referring to that black condom that slides over the end of the stud orifice. Why should it seal This was not a closed primary system. It helped seal the roads for years. Bob L
        AMCA #3149
        • 61 pan
          • Dec 2012
          • 17
          Ok I got the point the condom fit is sloppy in the hole and doesn't seal. ( i hate that) The main thing is the inter primary cover is on correct. thanks for your help.
          Jay
