Help can someone tell me does the lower tab on the inter primary cover mount to the inside or outside of the tab on the frame. While I'm here just to make sure ill ask the same question for the top one on the oil tank. Also does the spring go between the two tabs or on the backside of them.Thanks
Need help with inter primary cover for 1961 duo glide
Primary tab goes on the outside of the frame tab. Bolt goes on the inside with threads facing out. Then the inner primary, spring, washer ,nut and cotter pin.Last edited by Robert Luland; 04-07-2013, 08:24 AM.
When you say breather nipple? Are you referring to that black condom that slides over the end of the stud orifice. Why should it seal This was not a closed primary system. It helped seal the roads for years. Bob L
