CIMG6173 (2).JPGCIMG6174 (2).JPG What is wrong with these parts? I just purchased them separately from two of our members. The pins is supposed to be part#45031-65, hand lever pivot pin. The other is 45024-65, hand lever w/bushing. The pin is 13/32" in dia. The hole in the lever is a hair over 3/8" That is a no go. Any suggestions or info on this? Thanks. mike
1965 lever question
I'm a Sportster guy, but I'm pretty sure Sportster and big twin used the same lever in 1965 (first year for the new style.) The levers you have pictured are NOT the correct levers for a 1965. But like I said, I can only say that with confidence regarding Sportsters. Hopefully one of the Panhead experts can chime in and let me know if I'm correct.
Jerry is correct they are not the levers for 65. The 65 levers are basically straight with a small ball on the end, part #45002-65. No curve. If you have the parts or service manuals you can see them there or if you have any of the panhead restoration books they are shown there as well.
Tom (Rollo) Hardy
AMCA # 12766
Oh Jeez, here we go. First I will have to talk to the member who just sold me these levers with a part number of 45024-65. As far as the clamps themselves, I have been told that for 1965 they did NOT have holes for the mirrors, an still used the older separate clamps for them. I hate to say it, but I kind of thought I had the right levers, but I defered to older, more "knowlegeable" members on the proper part. Anybody know for sure on the right parts? I do have the parts book, of course. Yopu would have to be an idiot to not use it, but it also usually shows the latest replacement version of any multi year part. That goes both ways. Now, what are the levers for? Thanks. Mike
Originally posted by Rollo View PostJerry is correct they are not the levers for 65. The 65 levers are basically straight with a small ball on the end, part #45002-65. No curve. If you have the parts or service manuals you can see them there or if you have any of the panhead restoration books they are shown there as well.
Tom (Rollo) Hardy
AMCA # 12766
Originally posted by cdndewey View PostThose levers were available in the 1962 Accessory Catalog part# 45017-62 for a whopping $3.75, so they were definitely available in 65.Last edited by BigLakeBob; 12-25-2012, 04:54 PM.Bob Rice #6738
Originally posted by BigLakeBob View PostHere are my thoughts looking through my levers. All my straight ones (5 or 6) with a ball on the end have a 13/32 hole. I have one curved one with a ball on the end like you pictured and it has a 3/8 hole. If they did come out in '62 remember the pre'64 uses a shoulder screw that is 3/8 dia. Possibly they made it to fit either- as sold to fit the pre '64 style with 3/8 hole or reamed 13/32 by you to fit the newer style with pin and clip, or did this curved style stop in '64 and they went to a straight style with the larger hole in '65? So being in the accessory catalog, does that mean all pre'64 levers were straight except as an accessory with a ball on the end starting in '62? When did they go back to straight with the ball on the end? So if it was an accessory and you like the lever, ream it bigger to fit the bracket diameter, if not keep searching for a straight one. So I guess the original question still hasn't been answered by my ramblings. Bob AMCA# 6738
Also, the trimmed thickness of the part of the lever that is inserted into the clamp itself has a straight edge that rubs against the clamp on the curved lever, and the straight lever has a curved edge that conforms to the profile of the clamp om my bike. So can you me if the clamps are different on the pre-65 bikes?
