Frame and Paint
    That's the tab for holding the squish pipe. Will look at frame in morning. Bob L
    • jdapkay
      • Oct 2012
      • 13
      Thanks Jerry and Robert,
      The help on this site is incredible!! Robert I noticed your web site as New England. If you folks are up there hope all is okay.
      Joel
      • jdapkay
        • Oct 2012
        • 13
        Yes, Jerry I've had the same problem. I've looked at a couple bikes and same results, tab cut off. I will wait and see what you tow come up with.
        Thanks again
          Joel, hang in there. I will be going back to the shop in the morning and will measure the tab and post the dimensions. I'm getting real good with that flash light thing. Bob L
            Here ya go! Bob L
            • jdapkay
              • Oct 2012
              • 13
              Perfect Bob, now I can get that back on so the frame can be done. Thank you, I hope you didn't have to stand on your head to get those measurements!! Thank You!!!
              I'm sure I will have many other questions.
              • kg993
                • 263
                On the 65 that tab's not only for the squish pipe but also supports the passenger peg bracket coming from the transmission kick cover studs.
                Kerry
                Kerry AMCA # 15911
                • hennigan62
                  • Sep 2010
                  • 140
                  Dupont code for birch white is 809233k.
                  • jdapkay
                    • Oct 2012
                    • 13
                    Thank you kg993 I can see how that would work two on the cover then the peg bolt goes into the hole with the pipe hanger correct?
                    • jdapkay
                      • Oct 2012
                      • 13
                      Thank you much for the code big time help!!
