compensator sprocket
  • compensator sprocket
    I bought a compensator sprocket at rhinebeck and went to put it on and found that the main shaft was bigger than the compensator sprocket end nut are thier differnet size end nuts? If not what do i do ? Thanks need all the help i can get
    You may have a Sportster nut.
    Kerry
    Kerry AMCA # 15911
      thanks for the help thats what it is for a sporty thanks again
        Also, if it's an early compensator for a tapered shaft, the S & S shafts have a larger thread size, and the compensation sprocket nut does't fit ti.
