Ignition Coil: Replacing high tension wires
  • Schorsch
    • Feb 2009
    • 91
    Bought an old used OEM Ignition Coil for my 1949 Panhead. The high tension wires are missing, so i have to install new ones.
    How does i have to prepare the wire ends for proper connection in the coil ?
    Bruce Palmer III described it in his book (page 401) "bevel the end of the wire which is to be fitted into the coil ..."
    What does he mean exactly?
    George AMCA 2781
  • Panacea
    • Dec 2011
    • 36
    This topic has been covered over on the caimag forum a few times, check this link out...http://www.caimag.com/forum/showthre...-building+coil
    • Schorsch
      • Feb 2009
      • 91
      Hi Panacea, thank you very much for your advice. I found all the information i want to know about my problem!
      George
