Linkert M74b gasket nozzle
  • JosephJoe
    • Sep 2011
    • 36
    On 3/4 inch of the top of the nozzle is a kind of a gasket ring.
    I can't find anything like this in the H-D manuals.
    In the "Linkert Book 2.1"by Victory Library on page 6 there is shown a nozzle with a gasket.
    What is correct ? A nozzle with or without a gasket.
    Thanks in advance,
    Joe
    • 8247
    Joe!
    The phenolic seals used upon some military, 'bombsight', and perhaps other models, sat on the shoulder above the one you found.
    The M-74 series was not spec'd to use one, but worn venturi openings benefit from a thin modern seal.
    Thicker seals may be desired to locate the nozzle opening within the venturi bore, such as when 1 1/2" nozzles are applied to a 1 1/4" model.
    That's my best guess,
    • JosephJoe
      • Sep 2011
      • 36
      Thanks Cotten,
      The engine doesn't respond to idle- and highspeed needle movement.
      I'm searching for a possible cause.
      Joe
        • 8247
        Joe!
        Even with wear, and even reversed assemblies of some parts, the Schebler Deluxe/L&L Model M design is quite 'forgiving'.
        Even 'accomodating',
        as many fellows have forced tuning to allow for vacuum leaks.
        So before anything else, it is prudent to eliminate all possibilities of a leak.
        Curing even the tiniest of vacuum fissures will allow even a "wrong" Linkert to dial in reasonably.
        Please bubble-test if you have not already:
        http:virtualindian.org/11techleaktest.html.
        No vacuum leak is an acceptible leak.
        Even future ones. Even.
        Good luck!
