65 Pan Timer
  • junkyarddog
    • Feb 2010
    • 193
    65 Pan Timer
    Here is a picture of a 65 timer. Someone welded the gear on when rebuilding it.
    That is a 1966. Here is a 1965, minus the gear.
    • BigLakeBob
      • 2768
      They both look like 65 to me, what is the difference? Thanks.
      Bob Rice #6738
        Have you looked where they mount to the case?
          • 2025
          Both pictures appear to me to be 65's. Just that the angle is off on the first one. Jerry
            • 4791
            First one is definitely '65. So is Chris's base picture. '65 is the only one with the slotted top and early base. Chris needs to clean his glasses!
            Robbie
              Robbie,
              Where are the mounting tabs on that timer that they had in 1965?
                • 4791
                Chris,
                Look at the first picture.
                The mounting tabs are there, the angle of the picture makes them hard to see! The tab is facing you and at a very slight angle down, but it is there. '66 and up have a thick ring on the shaft. and that picture is of a '65 type.
                Robbie
                  • 8247
                  Can anyone identify the model of the base housing on the left?
                  Note indexing of mounting tabs.
                  Thanks in advance,
                  • diesel55
                    • Jul 2011
                    • 262
                    Yes they are both 65 circuit breaker bases .Had to look real close at first jyd picture looked like ears where cut off. Hope the weld holds could cause damage to motor
                    • junkyarddog
                      • Feb 2010
                      • 193
                      Chris
                      The mount ears don't show up well in that picture, but they are there. The 66/69 has a squared machine shoulder in that area. Are the sandwiched advanced weights correct for 65? All original 66/69 that I have seen look to be cast 1 piece.
                      Jim
                      • BigLakeBob
                        • 2768
                        I believe those weights are '65 only.
                        Bob Rice #6738
                          • 2025
                          At least part of 66 and maybe even 67 had the stacked weights. Jerry
