50 pan gas caps
  • Glenn
    Member to Remember
    • May 2007
    • 403
    50 pan gas caps
    anyone have the measurement of the original gas caps sides for a 1950 pan
    tia
    Moose
    aka Glenn
  • Matt McManus
    • Dec 2007
    • 142
    Approx. 11/16 with 3/8 of knurling.
      V-Twin carries a good reproduction
      • Glenn
        Member to Remember
        • May 2007
        • 403
        thanks for the info
        Moose
        aka Glenn
          Folks,
          Beware of V-TWIN's repops that have their vents moved above the gasket, as shown on the right in my attachment.
          Modern fuels can swell the gaskets and block the vents.
          Liberty lost a custom paintjob when I parked the machine in the sun.
          • Matt McManus
            • Dec 2007
            • 142
            Folks,
            The location of the vent on the V-Twin cap is the same as the original tall eaton gas caps. You need to trim about 3/16 off of the outside edge of the gasket and then your problem is solved. The same things will happen with original caps if you put new rubber gaskets in them.
            • Glenn
              Member to Remember
              • May 2007
              • 403
              guess I have the wrong caps mine are brand new eaton caps but too short
              Moose
              aka Glenn
