Windshield for 1965 Panhead EGlide
  • Schorsch
    • Feb 2009
    • 91
    What is the correct Windshield top end for a 1965 Panhead EGlide?
    The flat one or the peaked one?
    George AMCA 2781
  • upsrod
    • Feb 2010
    • 320
    Peaked..............
    • rbenash
      • Jul 2001
      • 643
      A follow up question - when did the peaked windshields stop and the "flat tops" start? I.E. - what is the transition year? Out of the country right now and can't look at my '65 sales brochures and detail nor the accessory catalogs.
      Ray
      AMCA #7140
      • upsrod
        • Feb 2010
        • 320
        I'm guessing the round or flat top started sometime in 1966.
          • 4790
          When the batwing fairing came out in '67 it had a flat (or round top) windshield. The regular type did too!
          Robbie
          • rbenash
            • Jul 2001
            • 643
            Kind of thought '66 for the windshield but wasn't sure without looking.
            Ray
            AMCA #7140
            • Underdoggie
              • Mar 2009
              • 100
              Ray, My fall 65 accessory catalog shows the peaked window. I have seen a couple of 65's with flat tops and the darker bead color like the orginals had and the owners claimed they were original. I have not personally seen a 66 with a peaked window with the dark bead.
              John Underwood
              AMCA#14400
              Central Illinois
              • 36 knuck man
                • Dec 2009
                • 294
                My org 65 has the peaked, my org 66 has the rounded, thanks , Larry AMCA 4250
                • rbenash
                  • Jul 2001
                  • 643
                  Thanks John, I was thinking the same, that '65 accessory catalog showed the peaked style but out of the country right now so couldn't confirm. The original that was on my '65 is the flatter style with dark bead. So is the NOS replacement I have on it now. Didn't have my catalogs here (out of country) so couldn't confirm for this post. I have seen one '65 with the peaked style that was a totally untouched bike, dark bead. All the others I've seen had the flatter style, dark bead.
                  Ray
                  AMCA #7140
                  • gigolo258
                    • Nov 2010
                    • 35
                    upper windsheild
                    Larry is correct on the 65 peaked ,66 round question but the earlier post about batwing fairings being introduced in 67 is incorrect ,1969 was the first year for the fairing and the small tour-pac.
                      • 4790
                      Yup, that was me and I apologize for the wrong info. . I was thinking round top windshields, and it was actually the '67 style sidecar that had the round top shield. I knew it was something fiberglass in '67!
                      To exonerate myself I went out and actually researched rather than depend on memory and dug out a '66 Electra-Glide sales brochure where one of the featured changes is the "New Windshield Shape", and pictures the '66 with the round top shield.
                      Robbie
                      • Panacea
                        • Dec 2011
                        • 36
                        I've been searching for a new window for my peaked 64 shield, the original is hard to look thru. Are there any good replacements available? Is it possible to re-use the original beading?
                        • cdndewey
                          • Jan 2005
                          • 438
                          I thought 68 was the first year for the flat top.
                          • portagepan
                            • Feb 2006
                            • 580
                            National Cycle still sells the peaked style. The bead is clear. The older ones I have seen with the dark bead are just aged plastic. There is a man onebay selling the peaked upper for $100, saying they are rare. National still has them listed for $90. Go figure? Mike
                            • rbenash
                              • Jul 2001
                              • 643
                              Panacea - I think you can re-use the beading. I noticed on my windshield that the beading is kind of loose, not rattling or anything like that but pretty sure if I wanted to I could remove it. Treat it "gingerly" if you try but I definitely think it can be removed. I have an old windshield in the loft which would be the candidate if I were to experiment with removal
                              Portagepen - good note on the "yellowed beading" being due to age. The NOS flat top version I have is not yellowed.
                              Ray
                              AMCA #7140
