1957 FLH Ignition Switch
  • flhghost
    • Sep 2009
    • 19
    Does someone know if the correct ignition switch for my 57 panhead
    should have #s around the switch hole or should it be plain?
    Thank You
  • portagepan
    • Feb 2006
    • 580
    Palmers book says plain. No pins, no numbers.
    Mike
    • flhghost
      • Sep 2009
      • 19
      Thanx for the help Mike
      • awander
        • Nov 2001
        • 54
        Are you asking if it should have numbers around the keyhole?
        Andy Wander
        • flhghost
          • Sep 2009
          • 19
          Andy,Yes I wanted to know if it should it have #s around the keyhole?
            1947 was the last year for key numbers on the cylnder. 48 up had the neck lock and the switch cylinder was not pined. Any key will turn it. It wasn't till the late sixties? or early seventys? Maybe when they put the padlock thingy on the lower triple tree (Rob could tell ya dead on) That they started pinning the cylinders again. Bob L
            • upsrod
              • Feb 2010
              • 320
              The pinned and numbered switches started up again in mid 1963.
