Welds
  • whitey1j0
    • Nov 2010
    • 26
    Welds
    moved post
    Trying to figure out what your asking? If it's the neck casting? The welds go all the way around the two down tubes and the top main tube and the renforcement tube.
    • whitey1j0
      • Nov 2010
      • 26
      Tank mount welds
      001.jpgWelds
      Could someone tell me where the welds go on the front gas tank mount on a '56 Pan frame, I don't know if it welds all the way around or just on the top and bottom of the legs, Thanks, Whitey
      • Chuck#1848
        • Oct 2004
        • 920
        Not a 100% sure Whitey but ,I am about to get into the samething with a 57 Pan frame where did you get your frame mount brackets from?
        Chuck
        AMCA Member#1848
        • whitey1j0
          • Nov 2010
          • 26
          wascoframe on ebay
          • Chuck#1848
            • Oct 2004
            • 920
            I kinda thought so, Thanks!
            Chuck
            AMCA Member#1848
