1938 to 1940 Springer
  • Steve Little
    • Apr 2008
    • 915
    1938 - 1940 Forward sweep springer on ebay
    http://cgi.ebay.com/ebaymotors/Inlin...item27b9db0dd9
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    • 6034
    I thought the rockers, for that era fork, would not have the raised zerk boss. Otherwise, nice fork for someone.
      Ben tell me the spring fork is a number 5.
      • Steve Little
        • Apr 2008
        • 915
        Eric's on the ball.
        I didnt notice the late rockers.
        Late rockers on 1938 to 1940 foreward sweep springer.
        Steve
        Steve Little
        Australia.
        AMCA member 1950
        • len dowe
          • Oct 2002
          • 520
          it doesn't matter what rockers are on it(late rockers were obvious). thats minor. looks like a later front leg to me, can't really see the hump if there is one. and no casting pics(ok ben). if casting #'s are good and no hump, zerks inside, 37 early 38.. easy fix for a prewar setup.
          AMCA #765
          • 48hdbob1
            • Nov 2009
            • 111
            So the '38-'40 fork has the hump above the numbers on the spring leg? thanks, Bob
              • 6034
              It's only minor if you already have a set of early rockers. And that reminds me; I need an early right side rocker if anyone has one lying about.
              • knuckleheadtim
                • Jan 2008
                • 141
                It has the later steering damper, so it's not correct for '38.
