Skull Dash
  • Steve Little
    • Apr 2008
    • 915
    Skull Dash
    A question on the skull dash 1936-1938.
    Was the extension skirt around the front of the dash cover, welded to the main body or spot welded?
    I know aftermarket covers have little tack welds but I have never had an original up close for inspection.
    Thanks in advance
    Steve
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
  • 36 knuck man
    • Dec 2009
    • 294
    Steve, good question, so I just went out to the shop and looked at 2 orig and one aftermarket. The org are spot welded and they also have a more distinct ledge on them than the after markets. The after market also had the 3 little, what looked to me like welds or brads to hold the skirt on, hope this helps, I was curious also, thanks, Larry
    • Steve Little
      • Apr 2008
      • 915
      Thanks Larry. I bought one of these aftermarket dashes from a distributor that I thought would be "OK" but it misses a hole and the dash hole does not fit so I thought I would look on ebay again and a seller has one for sale with an original looking dash base behind it. But it has welds on the inside so I will steer clear of it.
      Thanks for the info.
      Regards Steve
      Steve Little
      Australia.
      AMCA member 1950
        The lens in the re-pop is not installed anything like the originals either.
        • handshifters
          • 17
          regards, Joe
