47 Knuckle wiring harness
  • gallen
    • Sep 2006
    • 60
    I ordered a wiring harness from hummeremporium.com/motorcycle harness.com
    The color coding matches the factory manual. There are three wires that have a tracer on them just like the manual shows. My question is that I have seen on some forums that the wiring harness has quite a few wires with tracers.
    Which one is correct?
    Where can I get a correct harness if this is not correct?
  • cdndewey
    • Jan 2005
    • 438
    Check the wiring diagram in a service manual. That will tell you the proper colours and which wires had a tracer on them. If you don't have a wiring diagram let me know and I will scan one and send it to you.
      • 6039
      I am not aware of a truly correct aftermarket wiring harness. I believe they all come from the same source and I am not aware of another wiring harness maker. I just wired my '48FL and the harness was very close but some of the terminal lugs were not the same as original, and some of the wire guages were smaller or the insulation was not as thick. I saw a genuine H-D wiring harness on ebay that was bid over $500 and didn't make it's reserve. It seems to me, there is a real demand for an accurate harness.
        I know of at least two different makers of wiring harness. I am sure there are more.
        • len dowe
          • Oct 2002
          • 520
          Bruce Linsday makes the proper correct harness. Several people do sell his harness's. As far as ebay,,all depends on the time and who wants it..I personally don't run an original harness, I like the rubber insulated harness(and can still be judged). If you're riding and something burns, you'll be glad you had the insulation. Taken from experience...Len
          AMCA #765
          • sirhrmechanic
            Vigilis
            • Dec 2010
            • 1147
            You can also do your own 'harness' with supplies from Rhode Island Wire in (you guessed it) Rhode Island. They sell all the supplies, correct trace wires, etc. Their wire is cloth wrapped over a modern neoprene insulation. So you get the right look with modern insulation. They have all the correct ends, connectors, etc. They sell wire by the foot or the roll. Their catalog is a must-have for the restorer.
            Cheers,
            Sirhr
              • 6039
              I have always used Bruce's harnesses and I have no complaints. It is my understanding that certain terminal ends that were used by H-D, are no longer made. Some people are purists and demand absolute perfection. My post was submitted with that in mind.
              • gallen
                • Sep 2006
                • 60
                How would I get in touch Bruce Linsday?
                  Bruce Linsday, 17421 Chagrin River Road, Chagrin Falls, OH. 44023 440-247-4020
                    From what I've seen, every wire has a tracer with the exception of the horn which is solid black. Most diagrams only show the high/low switch with the true tracer colors. All the rest are the primary color with a white tracer. My 48 has a yellow with a black tracer for the front fender light but that's it. All the terminals as far as I know on your bike should be soldered as the crimp terminal came into play in 48. The majority of terminals on my 48 should have shrink wrap on them, but. Bruce make a great product but it's up to you to set it right. Bob L
                    • billpedalino
                      • Mar 2005
                      • 1096
                      I have purchased harnesses from three different suppliers and all vary in accuracy and correctness. God only knows where these harnesses originated and whether or not they came from the same source. I now have a pile of wires and connectors and make up my harnesses as I go. This way I have at least some control over accuracy. I did not know that Bruce was involved in wiring so I have never seen his harnesses, but I bet they're very close.
                      One thing I would ask is whether or not Bruce uses the brass flag connectors as did H-D. I would assume that if not, they are probably no longer manufactured.
                      Bill Pedalino
                      Huntington, New York
                      AMCA 6755
                      • Paquette
                        • Mar 2004
                        • 438
                        Bruce makes the best wiring harnesses and to my knowledge have the correct terminals although mine were done (the terminals) from an expert==
                          • 6039
                          What about these.
                          • gallen
                            • Sep 2006
                            • 60
                            Thank You I will get in touch with Bruce
