Springer Handlebars, oem vs repop?
  • onfullblast
    • Jan 2011
    • 5
    Anything particular to differentiate an OEM from (possibly early) aftermarket handlebar?
    on handlebar casting?
    I pickedup a inline standard and they look old. are brazed
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    The authority on OEM vs. repop would be tom faber: fabercycle on this forum. He knows more about the differences in H-D bars than anyone else I know.
    No one can help you without t least a photograph, anyway.
    Gerry Lyons #607
    http://www.37ul.com/
    • onfullblast
      • Jan 2011
      • 5
      thx, here are a few.
        The older imported re pop bars from V-Twin were crap (Imagine that). The center casting was too thick. You needed to file the bars to get the spirals on. Re pop bar from Tom Faber fits and looks right.
        • bill campbell
          • Jan 2009
          • 129
          his handlebars are the nicest being made and he makes sure your satisfied with the deal.as I found out ordering bars for a 1915 he sent what I thought was 1916 and later but I was wrong and he was right,and he still swaped them for the bars I wanted,and he's great to deal with very easy going
          • fabercycle
            • Nov 2006
            • 243
            Show a picture of the collar that the spiral stops against.
            • fabercycle
              • Nov 2006
              • 243
              Ok, I guess there's no more pics...... Your casting looks to be a repro from the looks of the pad around the center hole is wider than oem, and the tube sockets are not as tapered as oem. I'm guessing they are David Sarafan bars from the 80s. David isn't a fabrication shop, I'm sure he imported them from overseas. Doubtful if they are v-twin, as those would have even more issues that don't look right.
              Hope that helps you.
              • onfullblast
                • Jan 2011
                • 5
                collar pictures
                attached.
                Thanks for the input thus far.
