Help ID these Springer Risers please
  • Help ID these Springer Risers please
    Hi, hoping someone may be able to help id these for me. No markings / stampings that I can see. Any help would be greatly appreciated thank-you.
    H-D -49 part number. or a copy of them.
    Dave
      However, it is for an an in-line fork. Mid '46 and earlier.
        Here's the H-D add. Dave
          Thank-you for the info!!! Rick
            I have one of the HD acessory triple clamps also. You'll notice on the inside of the stubbs that the risers mount on there is a raised portion at the body of the triple clamp. This is true of the HD clamp. The flanders and other aftermarket clamps did'nt have this. Just an observation, in case you ever see one at a swap meet.........Rod
              By the way, what are you going to do with that riser ?
