Help ID these Springer Risers please
  • A.Sinner
    • Jul 2009
    • 28
    Hi, hoping someone may be able to help id these for me. No markings / stampings that I can see. Any help would be greatly appreciated thank-you.
  • BNSONS
    • Mar 2007
    • 178
    H-D -49 part number. or a copy of them.
    Dave
      • 6039
      However, it is for an an in-line fork. Mid '46 and earlier.
      • BNSONS
        • Mar 2007
        • 178
        Here's the H-D add. Dave
        • A.Sinner
          • Jul 2009
          • 28
          Thank-you for the info!!! Rick
          • Rod K
            • May 2006
            • 179
            I have one of the HD acessory triple clamps also. You'll notice on the inside of the stubbs that the risers mount on there is a raised portion at the body of the triple clamp. This is true of the HD clamp. The flanders and other aftermarket clamps did'nt have this. Just an observation, in case you ever see one at a swap meet.........Rod
              • 6039
              By the way, what are you going to do with that riser ?
