On an original Delco Remy 9 bolt horn what is an original cover made out of? Steel, brass? Does the year of the horn make a difference? I have one with a steel face and I want to know if it is correct for a 39 knuck. Any info would be appreciated
Delco Remy 9 bolt Horn
Tags: None
Steel faces were painted and brass faces chrome plated. Of course many painted faces got chromed after they left the MoCo.Be sure to visit;
what vintage is this
different than most you see, though i did see one of these in a complete EL collection. this one is mine. horn cover has less detailed shield and the wing tips don't turn up. it is "old". is it a remake/replacement or OEM. if it is a replacement, when did it come out? if it is OEM, for what years then? Will it be considered "correct" when judged for 37EL?
thank youAttached Files
It very well could be a reproduction. Reproductions have been with us for 30 years. A simple test is a magnet. If it sticks it is a repop. If it doesn't is is more than likely original. Original chrome plated horns were brass. Painted war production horns were steel but looked identical to the chrome horns.Be sure to visit;
On a RESTORED motorcycle it would be OK. On an UNRESTORED machine it would be a no no. Judging handbook says "6. Accurately reproduced parts count the same as
original while judging a restored category. However, in judging an original condition category
the part must be original."Be sure to visit;
