1937 big twin
  • flthead
    • Dec 2003
    • 412
    1937 big twin
    correct me if i'm wrong but these are the correct shifter pivot stud [threaded both sides,goes into gas tank bracket ] and break pedal pivot stud [again threaded on both sides ] for big twin flatheads and knuckles ?... judges jump in here
  • flthead
    • Dec 2003
    • 412
    responce from -http://www.hydra-glide.com/index.php
    FlatHeadSix Post subject: Re: 1937 bigtwin questionPosted: Mon Oct 06, 2008 3:09 am
    Moderator
    Both those parts are correct for the 1937 Big Twins, flathead or OHV.
    The Shift lever & Bracket Stud is part number 2206-37 (old number system) and was the first year for the double threaded stud. The shift lever stud with a shoulder and one threaded end was used from 1916 until 1936.
    The Brake Lever Stud is part number 2960-36 and was introduced the previous year, 1936, for the new knucklehead frame.
    mike
    tried explaining this to a guy going for his senior award that these where correct for his 1937 knuckle and he had wrong parts installed..... guess even the judges don't know what's right or wrong
