Electric welding
  • DANPATCH
    • Apr 2009
    • 313
    Electric welding
    I have tried 6011 6013 arc rods ,tig and Mig and can not seem to make welds look factory. Any Ideas
  • 1939wl
    • Oct 2023
    • 167
    Hi Dan,
    I am a CWI/CWE and rider, builder for over 55 years. What welds are you talking about? Frames etc. on our early bikes/Front Ends etc. were factory brazed, not welded.
    Maybe can help if you list what welds you are referencing. 6011 is a deeper penetration rod often described as the AC buzz box equivalent of 6010, and 6013 is a low penetration
    rod for sheet metal, and thin materials....they have very different characteristics.
    Member # 8964
      • 2024
      I have welded many frames with 3/32 7018 rod and was happy with the outcome. You could always go back to oxy acetylene.
      Jerry
      • DANPATCH
        • Apr 2009
        • 313
        Electric welding of 1947 frame.The 7018 is very close
        This gallery has 2 photos.
        • otis71
          • Jul 2015
          • 597
          3/32 7018 is definitely the best rod for your application. Try positioning the frame so the weld is flat, ie the tube is vertical. A bell hole weld where the tube is horizontal is most difficult.
