I have had this original Paint fender for years .Came off a 41. Has 2 strips one each side. It was held on with we use to call speed nuts. They were is auto body moldings.I still had some left over.
1941Squash Bird original hardware
These are photos of what I think is an original squash bird and side strips on my 1941 Knucklehead.
IMG_3590.jpeg IMG_3589.jpegRichard Spagnolli
AMCA #6153
Howdy chaps,
Sneak one in here while this thread is wandering off topic. Can anyone identify the source of the Chevron and fender strips affixed to my 41 FL? They were acquired NOS in a box in the early 80’s when this machine was restored by the previous owner. Thanks in advance.
They are various parts of this set which was standard on '40 Deluxe package and available for several years over the counter. The shorter set along with the chevron on the front fender, the longer set on the rear fender.
DCP_4121.JPG DCP_4122.JPGRobbie Knight Amca #2736
Thanks Robbie! This machine was owned/restored by the gent who has the 36 called Flying Cloud and this was his first of many Knuckles since.
[QUOTE=PRG;n350176]Howdy chaps,
I do not know about the stripes but the Chevron is a 1940 HD item on I think all 1940's except the utility option.
Jerry
PRG
Very nice ........... Do you have a pic of chain oiler screw/bolt that goes straight in as oppossed to the later ones that go at an upward angle which I have seen or does your have the
newer style ??
Stainless trim first year goes thru 46 correct..
7’’ Air Cleaner with a longer manifold
Airplane style Speedo with black background and easy to see white numbers with a bigger needle painted white.
neck rake increased to 28° from 25° and forks were straitened
no longer swept forward.
Die Cast brake handles (2 year only no slots for cable)
one year only oil pump chain oil screw goes straight into body
42 and later the chain oiler screw goes in at an angle,
Clutch pedal running on two bushings and a grease fitting on pivot point for easy maintenance
Clutch shift linkage is one piece forged steel instead two pieces steel rod that are either brazed or welded together.
Tool box brackets held in place with 3 -1/4 x 24 bolts and for most 41 models mounted up high along frame rail
New ROCKET FIN Muffler used till 49
Notes I have made reading this forum ,Dale's WTTM vids and Carls Cycle shop vids -you guys are a wealth of information thanks !
"you gonna sit there and argue ......or FISH " Claude Leadbetter
The pump on the left is in my opinion 1941 and early 1942 when it was replaced by the pump on the right. In the 2nd picture the the 1941 pump is on the left and the pump on the right superseded both of them in 1945/early 1946.
JerryDSC04435.JPG DSC04433.JPGLast edited by Jerry Wieland; 07-03-2026, 08:31 PM.
