Linkert Paint
  • 41craig
    • Nov 2010
    • 410
    Linkert Paint
    This may have been covered before. What is the best paint for Linkert Carbs?
    Thanks, Craig
    Thanks, Craig
    This is the most fuel resistant coating I have found, Craig,
    https://sigmfg.com/products/sig-supe...pr_seq=uniform
    They make silver as well, not sure about O.D.,
    .....Cotten
    PS: I hate paint.
    • Saddletramp
      New Old Member
      • Aug 2011
      • 130
      Craig,
      My M74B was polished back in the early '80's. Carb body and float bowl. It's a little tarnished, but would probably shine right up. It's going back on the '60 Pan one way or the other but Palmer says it should be black. Not sure what I'm gonna do with it. Thanks for the info Tom BTW..
      James.
        When I was active, Saddletramp,
        The standard procedure to recover a polished carb was first to add character with abuse,
        then shot-peening, then ALOX blasting, before beading and Nylox wheelbrushing.
        Then prep for enameling.
        PS: Polished bowls usually started with the shotpeening step, and finished with machining the gasket surfaces of course.
        The end result is the same as hammermark removal:
        • Saddletramp
          New Old Member
          • Aug 2011
          • 130
          Good info Cotten, May end up being the route I go, or similar eventually. Thanks.
          James
          • 41craig
            • Nov 2010
            • 410
            Thanks Tom!
              • 6034
              Isn't that destroying history, Tom?
                I believe I already mentioned elsewhere, Eric,
                The judging system made me money!
                .....Cotten
                  • 6034
                  My apologies, Tom. Shouldn't have posted it, and too late to delete.
                    No offense taken, Eric!
                    Preserving History needs more discussion.
                    How many judges could spot me faking it?
                    'Bout the only thing I never faked was numbers.
