Horn Button
  • 47Knuckle47
    • Jan 2021
    • 26
    Horn Button
    Seems I ordered the wrong button, I needed a 1 wire (OEM 71800-26A. VT 32-0557)) but instead got a 2 wire that shares the same OEM number but not V-Twin part number which is VT 32-0400 can I eliminate the green wire and still use. Unfortunately, I have already fed through the bars.
    Tim
  • dukekleman
    • Jul 2022
    • 596
    Tim,
    If you want to use the (2) wire button, you'll need to connect the 2nd wire to a good known ground location.
    Hook the 1st wire up per the schematic and your horn will work when the button is depressed.
    Hope this helps,
    Duke Kleman
    • 47Knuckle47
      • Jan 2021
      • 26
      Excellent, thanks for the response
